  • Replies 125
GIVING THIS A FEW MORE DAYS JUST TO GET THE STRAGGELERS ALL DONE, AND ITS CAUSE OF MIKES LATE REPLY WE ARE BEHIND,LOL...
PM ME FOR LAST MIN ORDERS PEOPLE.
my apologizes Kezza! LOL, you know we had Golden Week holidays, so it took me forever to get back to ya!!
anyways we're all set and ready to go now, haha
ok, people who are on the list of love.lol
1..M Riffel for bezels for his R32 GTR money sent YES
2.. J charalambous R32 GTS-t white face dials and a set of bezels money sent YES
3.. C Law bezels for his R33 money sent YES
4.. V doan R32 GTR dials money sent YES
5.. Macguyver R33 AUTO bezels money sent YES
6.. Frink luke S R33 GTS-t dials money sent YES
7.. Wogboy R34 GTT Manual bezels money sent YES
8.. n15mo R34 GTT auto bezels money sent YES!
9.. HUM@NZEE WGN 34 bezels ENG money sent YES
10.. R.freeman(arep3) R32 GTR bezels money sent YES.
11.. Mr Cali R32 GTR bezels money sent YES
ALL BANK TRANS ARE COMPLETE, THANK YOU AND WILL BE ORDERING AS OF NOW. 3\06\06
SORRY TO ALL FOR DELAY....LETS ROCK
Edited by kezza
they have been ordered, money has been sent to japan.. They had some drams with Years of some of the car, cause some dashes changed a little from year to year.
All sorted, they are being gathered as i type.
Will reply with news of them all hitting my door, so you know they are not too far away!
kezza
Cheers for the updates Kezza, top stuff! :devil:
Not a problem, i know what its like to have sent hard earned money some were, I know i would like to know whats going on if it was me... i cant wait too i got a set of bezels for my car on the way too!
Should be sweet as. :D
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
