Doods
My front bar, grille and bonnet are getting replaced now...I can get some aftermarket ones and wondered if any1 had any suggestions?? I'm keen on 400R, GTR styles....or any other suggestions
If you either have some for sale and know of a good place..let me know asap!!!
thanks
KJ
https://www.sau.com.au/forums/topic/115651-new-s1-front-bar-bonnet-and-grille/
http://www.skylinesaustralia.com/forums/in...howtopic=108696
Mate i got a front bar im selling at the min if your keen...
dont have a grill but any would suite...
PM me if you want any more details etc
buy that 1....suits the S1 to a tee
Word. That one's nigh on perfect.
Mavric - how well does it fit? I'm thinking about a new bar but a lot of the 'glass ones i've seen leave a nasty gap under the lights (that being said i've only looked at a few.)
funny enough I saw you one and was about u send u a PM....u should have sone soon!
Fits perfect... If you look at the link for the sale of the bar ... http://www.skylinesaustralia.com/forums/in...wtopic=108696...
you will see if you zoom into the pic of my car it fits no worries at all...
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
