I've somehow got water into my indicator and reverse tailights (from rain or from washing the car). Just wondering if there was an easy way to get the water out? Sometimes it fogs up from the inside. The water just stays there as you can see a small pool at the bottom of the light (probably won't see that in the picture).
Thanks..
https://www.sau.com.au/forums/topic/115674-water-in-the-tailights/
Yep have the same problem on my 33. I took the spare tyre out and found a nice puddle too. Skylines have been suffering from this since the R31. I tried a weather seal to no avail. Will prolly silicone the bastards up like I did with my 31.
I took the lining off behind the lights and took the bulbs out, i tried to dry it out with a heatgun. It probably would of worked but it would take an eternity(and probably ruin the plastic too from the heat). I was given a suggestion to drill a small hole in the corner of the lenses....but I don't want to do that. I might try to shove a rag or something in there next time and try to soak it up.
It's a bit of a bummer.
Lol mine has the exact same problem too. A friend has suggested to drill a small hole at the bottom to let the water flow out. What do you guys think about that?
I don't like the idea of drilling holes into my car..... plus by drilling a hole it'll probably make an entrance for dust and dirt to get inside the tailight, then it'll be even more of a pain to clean out :
yeh I had a leaky tail light (water would fill up in the indicator), i tried sealing it but that didn’t work so i ended up drilling a hole (closest to the boot) in the bottom. Haven’t had water in the boot since. I wasn’t too keen on drilling a hole either, but then again i wasn’t too keen in having water in the boot which would eventually lead to a rusty boot. As for the inside of the light getting dust and dirt haven’t had any problems. The indicator was slightly water damaged in the first place (slightly darker) but it’s hardly noticeable.
-michael
Had this problem after car came back from panel beaters for minor rear end damage. They had'nt sealed them up properly.
I proceded to take them off and fix it myself with a tube of silicon sealer.
The key is to ensure all the old sealant is off and both the light and car surface are fully cleaned of old sealent, with something like myths or grease and wax remover. When you run the fresh sealant bead onto the light, use plenty so that the surface of the sealant sits quite high. This will helps it seal nicely when mounting to car.
Now, there are two bolts, in between and above and below the two afterburners on each tail light unit (mounting side!). Make sure your silicon bead runs inside these two bolts, so your bead sorta looks like a figure 8 as opposed to ab oval. Also from memory there are thin rubber washers on each bolt, presumably to seal them from water, make sure you get new ones if need be. I would also put the sealer "join" at the bottom, just in case it sets with a minute gap, perhaps put a bit extra down there.
If anyone wants pics of the back of the light unit let me know so I can post up. Otherwise, this is an easy job that should be done in less than a day, getting all the old sealant off can be a bitch though.
Just thought I'd add that I did this about 3 years ago, and haven't had any leaking issues at all since. And you can tip excess water out when unit is removed, put in hot water cupboard with light sockets pointing up overnight, all condensation/drops should evaporate fairly quickly.
I might take the easy way out and drill a hole in it then.
I've tried to take the whole assembly out but the sealant is holding it on like something stupid, I'll end up breaking it.
Drewr33, I haven't heard of anyone that can repair cracks in plastic, i'd say you'd be in for a new lens (if they're available as a seperate part, I'm not sure). Please correct me if i'm wrong.
Thanks for the reply's guys :O
I guess I'll do the same as soon as I get my hands on a drill. Hope I don't drill too big of a hole. Lol.
I'll be slightly off topic but does anyone know what I can use to remove double-sided tapes on rubber as I just removed the window visors which came with the car. Currently they're just stuck there looking ugly as ever.
You could use turps. It'll softens up double side and gets it off really well. Just do whats recommended and try it on the rubber in an inconspicuous area first to make sure it doesn't eat the rubber. I'm pretty definite it won't hurt the rubber, just don't rub on clear plastic (it fogs it up really well....permanantly).
Pardon me but what are turps are where would I be able to get them? :P
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
