Hey people,
Have got for sale:
1 * BOSCH Genuine 040 Pump => good for up to 370HP $220
1 * BOSCH Genuine 044 Pump => good for up to 700HP $240
Both are brand new in unopened plastic, bought them a while ago, didn't use them, they are no longer needed.
Also,
1 * Unbranded Bosch Equivalent 040 Pump => $180
This is effectively a 040 pump, but without the Bosch stamp. Manufactured in the same factory, EXACTLY the same as Genuine Bosch. Assured quality without the higher cost.
Will post anywhere, at buyers expense. May deliver in Eastern Suburbs if needed.
PM or call for quicker response
Thanks,
Mat.
0400 558 030
Bosch 044
Bosch 040
Unbranded 040
Edited by femno
am i reading it rite u want $250 for the BOSCH 040? have a look in the business section mate these got for $235 at my door step..
tis only 15 dollars n postage is a couple more.
Ill give you $200 for the 044 and ill pay postage let me know.
Sorry mate 250 is already cheap. Thats the best i can do. You wont find one anywhere else for that price.
have u got any 044's left. these will suit r33 wont they?
dumb question, just making sure.
is the o44 straight fit into the r32 gtst?
To an extent. The 044 can be fitted into the tank no probs, the cradle requires minimal modification, and you will need two fittings for the pump, one for either end; and because the 044 is an external pump, you will also need a sock for the IN side of the pump to allow you to fit it internally.
Hope im not too confusing, you should probably have it fitted by your mechanic.
PM me.
Mat.
Whereabouts in Melbourne are u located?
Cause im in urgent need of a fuel pump for my R32 Gtst..
Thanks Thalia ;)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
