GTRs have better engines, g/box's, diffs, gards,seats and suspention, wouldn't it be better to simply remove
the front diff and drive shafts (if you could be bothered) to offset the very slight weight disadvantage than to build up a GTST? trust me, i've done it!
Better what?
box, diff - no
gards - not sure what you are getting at
suspension - stock for stock its all average
seats - GTR seats are not as flash as you think
Better what?
box, diff - no - i'm talking about a 32, and yes thay are stronger
gards - not sure what you are getting at -fit wider rims and more lock
suspension - stock for stock its all average -i'll give you that one
seats - GTR seats are not as flash as you think -have you drifted in both, gtr seats are better
  • 4 weeks later...
race and rally r32 gtst-$6000
-$2000-$4000 rb25/26
-$1000-$2000 rb25 gearbox
-$600-$2000 better seats
-$1000-$2000 wider gaurds
-$800 gtr cradle (diff and drive shafts)
tatal-$10500-$16000 plus labour
race and rally r32gtr-$10000 allready cheaper and no labour
Well add up what it costs if you blow a motor (Rb26's are not cheap to rebuild) and finding parts is just a pain in the arse.
Compare it to a R32 GTS-t with a lo comp RB25DE, strap on the hairdryer and dial in 16psi and you have 270rwk's and lots of torque.
We all know that torque equals fun :P
The main reason Adam asked this question in the first place was becuase he only had the GTR and we had our first Drift day here on the Apple Isle.
He now has a drift pig and i believe the GTR will be left for its daily driving duties :)
Cheers GMB
DrifTas
Im pretty sure he was waiting for it to arrive but didnt want to miss out on the drift day :)
Put a 1.9MM metal gasket in (should pull the compression to 10:1) and it will handle that on its ear.
Rev better than any worked Rb20, more torque and about the same cost as building a forged 20 :D
I know which one i would be going (i need $$$ :) )
GTR was fun at the drift day. Power burn outs. GTR's are a shit drift car. Having drove my gts-t last weekend there is no comparason. Grandmaster B was right I didn't want to miss the drift day. I am going to post pics of my gts-t drifting lastweekend. Enjoy. :angry:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
