Hi Guys - Thought I would put it all in one post -
I have for sale
R32 GTR ABS UNIT - its a bit dusty - but Was working fine when removed.
$SOLD
(FYI these are over $4000 from nissan)
(Pics Soon)
1 used Blitz Blow of valve with RB20/25 Adaptor
$SOLD
Buddy Club P1 Wheel. 17x8 +22 5x114.3 Hypergold. Almost new - but has a scratch on one spoke.
$SOLD
Greddy Profec B Boost controller. Good working order - holds boost nicely (even at 1.5 bar :wave: )
comes with EVERYTHING + english instructions.
$SOLD
email me [email protected] or PM
Kind regards
Steve
Edited by Antimatter
https://www.sau.com.au/forums/topic/115948-r32-gtr-abs-unit/
Bump
I also have for sale
genuine and Good working order
$180
Can send anywhere
Pics soon if I dont sell prior
[email protected]
Icydude - sorry - no, But I would suggest it would be best to rebuild it anyway. All I can say is it was not slipping when it was removed.
Musky - I will try to get some pics up on the weekend
JNJ - sorry - have no need for a bumper and wing (at this stage :/ )
CJlancer - pics soon - located in melbourne
Thanks!
Sorry - dont want to separate - you could always buy the whole thing and just sell off the BOV yourself :/
would u sell the blitz adapter off the blow off valve seperate? if so let me know how much
I have for sale
1 used HKS SSQV Blow of valve with RB20/25 adaptor
(both genuine and good working order)
$170ea
RB26 TURBO DUMP PIPES - HKS STYLE - BRAND NEW inc GASKETS
$200pair
Nismo/Exedy Twin plate clutch (push type) from 1990 GTR. USED -Was not slipping when removed - comes with lightweight flywheel.
$200ono
$150ono
Greddy Profec B Boost controller. Good working order - holds boost nicely (even at 1.5 bar :P )
$290
HKS Super Power Flow intake kit for R32 GTR - EXCELLENT CONDITION - All clamps, hoses, brackets and adaptors included
$200ono
Kind regards
Steve
Hi Steve,
Im interested in the clutch assy you have for sale, im on the Gold Coast, so was wondering how much inc freight to get it here ?
Cheers. Jay
Steve, can I come take a look at the dump pipes? I have plenty of time on my hands so anytime during the day.
At this stage I'll take them if you are willing to hold.
