Server is now up with Correct password and the following Maps.
32 Player Map (with room for 64 players)
Strike at Karkand
Daqang Oilfields
Wake Island 2007
Please advise if you have any issues.
PB_SV_GUIDRelax 4 has been run on the server.
(Thanks for posting the command who ever that was)
I have to do some work, but I will jump in later, I have advised the clan what is going on, and they may or may not jump online as well.
Any Problems Either SMS me (Urgent Issues only), 0410 491 599, or Xfire me, and I will get to it ASAP.
If Punkbuster causes issues (I had a shitfight with it yesterday, let me know, and we will turn it off completly, will require restart of server)
  • Replies 146
Posted Images
I am having issues getting in.
I am using Xfire, it asks for a passwd, I type in the supplied passwd as per pm and it throws me out stating passwrd incorrect. :P
With regards to teamspeak, there really isn't any need with BF2 as it has its own built in team speak thingo does it not?
The password is sau
Teamspeak is better then BF2's VOIP 'cause it allows chatter not just inside each squad.
However, it is entirely up to you what protocol you want to use.
As for Closing time, no, as yet, I don't have an official closing time,
I will try and keep it open for as long as possible.
Estimate at least 8pm this evening, maybe longer)
Was a pretty dismal turn out.
Last time i do something like that.
But i will thank those people that came in as well as those who help made it happen!
dont loose heart man not ur fault it was organised the same day time as a cruise i think make it for 9pm again on another sunday and most of us could probably make it
as sum1 else posted they thought it was @ 9pm
Yeah, Sorry guys that I wasn't able to turn up.
Unfortunantly, my time of procrastination about household chores caught up with me, and I was forced to do them on Sunday.
Let me know the date for the next war, and as long as the Clan don't have plans for it, I am more then happy to allow you guys to utilise the BF2 Server again.
How was the server for everyone? Stable? any Issues? (We had issues the night before, So I just want to make sure everything went ok on the day)
Next time, We will start the server with 16 player maps, then upsize them as required...
(64 players on a 16 player map would be insane :thumbsup:, Let's see if we can pull it off :wave:)
Edited by Anthos
Once I reformat my machine so I can bloody get BF2 working again I'll definately be keen for a few games and will try and get some others I know to join in as well.
It's been a few months since I've played though. Apparently I can't jump and throw C4 anymore :D
Apparently I can't jump and throw C4 anymore :P
Thats right and if you havn't played it since about that time then they have made some other changes too.
PS if you wanna join the next one initially its looking to be not this weekend coming but the floowing sunday, which would make it Sunday 4th of June
Ok I have put my reminder on for Sunday the 4th of June at 9pm.
Is it the same server?
Sorry I couldn't make it either lads. Unfortunately I was out helping fix a mates car at that time. As previously suggested, a later slot would be better around 8 - 9pm.
Bit hard for alot of people to make it at lunchtime on a sunday, especially if they have been out on the turps the night before :sweat:
Will take some time before you get some good turnouts, hang in there
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
