The h/lights will fit, the top inner bracket is different ( its higher than the sI+ sII) so you just do away with the spacer that secures it to the grill.
Good luck finding a set though ..
I fitted mine last night, they fit ok... some notes
- the bracket for the grill thats on the headlights is different but just dont use the space as wrxhoon said
- the plug has extra guides on it you'll need to file/cut off to get them to fit, but they still clip into place and work fine once you have done that
- the ballest underneath the headlight may have trouble fitting if you have something like an oil cooler undearneath your headlights...
- the half beam plug on the side of hte headlights is different, so i just used the bulb from my original lights, they fit fine....
Expect to pay around 2000 for a set, or over 3000 new from nissan....
