I just last night flushed out my rb20det and replaced with fresh coolant..now my problem is that the thermostat wont open, when i drive it it reaches just over 3/4 and the bottom radiator hose is stone cold when i put my hand on it after a drive, I have taken it out and tested it in hot water and it opens properly all fine. put it all back together put the bleeder nipple to the top and also checked for anthing that could be stopping it from opening, there was nothing. I was told today that there could be an air pocket that would prevent the water from making proper contact with the thermostat....is there only one bleed hole or is there a second one lower down on the engine for the thermostat housing??
https://www.sau.com.au/forums/topic/116294-overheating/
Do you have the correct thermostat for your car? If the rating is much higher, then it won't open when it should.
Other thing may be the waterpump. If it died, then it won't circulate the water.
And if you want to get any possible air out, there may be a better way, but I only know of the one that involves starting and running the car at idle with the radiator cap off until the bubbling stops. If your pump is working properly, you should eventually get coolant spilling over the top as the car warms up.
https://www.sau.com.au/forums/topic/116294-overheating/#findComment-2139105
Use something like a coke bottle cut in half, with some tape wrapped around the mouth piece of it so that it fits tight in the radiator filler neck. pull bleed screw out, run motor and keep filling bottle up, so that water sits higher than bleed point on inlet.
Does that make sense ?
Also make sure your heater is turned on, ie set climate control to hottest setting.
Give the motor a good bleed. You can also squeeze the top radiator hose occasionally while bleeding to force any air which can tend to sit in there.
Good luck
https://www.sau.com.au/forums/topic/116294-overheating/#findComment-2139858
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
