can someone help me out here i have a r32 with minor mods, but the weird thing is that the turbo doesnt start to spool until 3 to 3.5 grand and hits full boost at around 5grand, wat does this mean is it not standard turbo or is it fu%^ed.
any help will be appreciated.
Joel.
This will sound weird but my r33 was doing the same thing and it turned out to be my fuel pump so i put a walbro in tank one in and it is fine now. Im not sure why the boost was coming on late all i no is that the new pump fixed the problem.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145853
"""has the car been feeling sluggish? is it noisier at all when under boost?
you may have a slight leak in an intercooler/inlet pipe? checked all the clamps?""" (Azzurra)
no not slugish at all. it does seem to sound a little noisy i'll check the clamps...
well it has an aftermarket fuel pump an gtr injectors, an a malpassi fuel pressure regulator, but iv also noticed it only does it sometimes. Also Is there anyway to tell it the turbo has been high flowed-(rebuilt) without removing the turbo its self.
cause iv tested it on 12psi boost with out a FMIC an it runs perfect, iv been told not to run more then 10psi without a FMIC. i dont kno wats been done to it personally. also has a high flow cat an 3" system.
Edited by HR32_GTS-T
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145964
just sitting idling for a while, give it a bit, an then give it a bit later an it hits full boost at 3grand instead of around 5grand, weird i kno, but everything runs sweet an she go's hard, wat about the boost controller, i have no idea wat brand it is either, but it looks shitty.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145998
mate my car has the same problem i hit boost at 3000rpm but dont hit full boost till i hit 4500rpm i have a rb25det neo with an r33 turbo on it i wood like to no y it is doing this as it only just started playing up
i will go and c my mechanic tomoro after work and ask him i will let u no how i go.
ps if any one on here can help me plz let me no thanks
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146474
Check to make sure the wastegate actuator is not staying open. If it sticks or is getting stuck on something then it will be bypassing the exhaust gasses around the turbine. The easiest way to test this device is with a radiator pressure tester. Use it to pump pressure into the housing and confirm that the pressure it opens at is equal to the factory specs. If check is ok remove the mounting point where the actuator connects to the wastegate arm. There should be a small circlip. Use a pick or small screwdriver to remove it but be careful not to lose it. Check to make sure the arm moves freely and can open and close fully without interuption.
Check to see how easily the arm moves back and forth in the diaphragm. It should be difficult to move.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146807
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
