can someone help me out here i have a r32 with minor mods, but the weird thing is that the turbo doesnt start to spool until 3 to 3.5 grand and hits full boost at around 5grand, wat does this mean is it not standard turbo or is it fu%^ed.
any help will be appreciated.
Joel.
This will sound weird but my r33 was doing the same thing and it turned out to be my fuel pump so i put a walbro in tank one in and it is fine now. Im not sure why the boost was coming on late all i no is that the new pump fixed the problem.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145853
"""has the car been feeling sluggish? is it noisier at all when under boost?
you may have a slight leak in an intercooler/inlet pipe? checked all the clamps?""" (Azzurra)
no not slugish at all. it does seem to sound a little noisy i'll check the clamps...
well it has an aftermarket fuel pump an gtr injectors, an a malpassi fuel pressure regulator, but iv also noticed it only does it sometimes. Also Is there anyway to tell it the turbo has been high flowed-(rebuilt) without removing the turbo its self.
cause iv tested it on 12psi boost with out a FMIC an it runs perfect, iv been told not to run more then 10psi without a FMIC. i dont kno wats been done to it personally. also has a high flow cat an 3" system.
Edited by HR32_GTS-T
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145964
just sitting idling for a while, give it a bit, an then give it a bit later an it hits full boost at 3grand instead of around 5grand, weird i kno, but everything runs sweet an she go's hard, wat about the boost controller, i have no idea wat brand it is either, but it looks shitty.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2145998
mate my car has the same problem i hit boost at 3000rpm but dont hit full boost till i hit 4500rpm i have a rb25det neo with an r33 turbo on it i wood like to no y it is doing this as it only just started playing up
i will go and c my mechanic tomoro after work and ask him i will let u no how i go.
ps if any one on here can help me plz let me no thanks
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146474
Check to make sure the wastegate actuator is not staying open. If it sticks or is getting stuck on something then it will be bypassing the exhaust gasses around the turbine. The easiest way to test this device is with a radiator pressure tester. Use it to pump pressure into the housing and confirm that the pressure it opens at is equal to the factory specs. If check is ok remove the mounting point where the actuator connects to the wastegate arm. There should be a small circlip. Use a pick or small screwdriver to remove it but be careful not to lose it. Check to make sure the arm moves freely and can open and close fully without interuption.
Check to see how easily the arm moves back and forth in the diaphragm. It should be difficult to move.
https://www.sau.com.au/forums/topic/116674-r32-stock-turbo/#findComment-2146807
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
