Im doing an engine conversion and putting an rb25det and auto box into a datsun 260C, and on the weekend i was trying to rip the wiring loom for the auto box out of the car. (just to confirm, the computer for the auto is behind the drivers kick panel isnt it?)
Anyway the loom from the auto computer goes up under the dash then 3/4 of it goes thru the firewall and the rest goes into a big loom plug.
Now the problem i have is what the hell do i do with the wiring that goes into the plug?
Im guessing some of it is power to the computer and shit, but obviously a wiring diagram wiould tell me this.
So can anyone tell me where i can find a wiring diagram?
Or does anyone have any tips?
Im really pumped up about getting the conversion done but the auto wiring is really giving me the shits at the momeent.
Also another problem is the wires that go to the shifter have been cut, which im guessing are the wires for the overdrive?
Any help will be greatly appreciated.
Scott
Edited by BEV11S
https://www.sau.com.au/forums/topic/116904-rb25det-auto-conversion/
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
