ITEM:
1990 RB30ET powered Nissan Patrol LWB (7 seater)
CONDITION:
Good for 16 year old car with minor bumper damage.
REASON FOR SELLING:
Wanting Nissan Skyline or Z.
PRICE AND PRICE CONDITIONS:
$7,000 with rwc, $6,500 without, I'm negotiable. ***OFFERS WILL BE CONSIDERED*** Now trades may be considered.
EXTRA INFO:
The Patrol has turbocharger kit fitted by previous owner before me, it provides extra power needed when towing heavy objects (caravan/boat). I have once towed a broken car, it has performed faultlessly. I've driven carbuettored RB30 and TB42 verisons of GQ Patrol even fuel injected TB42, it simply doesn't match the power and economy of this Patrol.
The Patrol has travelled 148,000kms (approx) and the interior is in good condition, the mechanics are in good condition with regular servicing every 5,000km. It has towbar. It also have factory diff-lock (diff ratios are 4.3: standard with 3.0).
As i've mentioned, the Patrol has minor damage on front bumper but it can be replaced by either other bumper or bullbar (buyers to replace it).
As some people might find it expensive, and i know the market is bad at the moment. I can be negotiable with pricing. ***OFFERS WILL BE CONSIDERED***
Frankston South, 1 hour south of Melbourne.
PICTURES:
Below, Email me for more and i'll send it.
I can be contacted through PM or Email.
Email address: [email protected]
And there is other stuff i proabably forgot, if you have questions please contact me.
Thanks for looking.
Grant.
Edited by Dreamer 33
https://www.sau.com.au/forums/topic/116990-90-patrol-for-sale-or-swap/
  • 1 month later...
  • 1 month later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
