Heyaz
Any way a while ago i bought a pod filter and a adapter for my r32 gts-t type M and have just been looking for the time to make up a cold air intake box for it. But i have been reading and it seems that quite a few people running reasonably stock gear, havent bothered with the air intake box (although a couple of the people are running new turboes, injectors etc.) They just have the pod in the engine bay. So, a pod sucking in warm air, sucks enough in to make it better than the standard panel filter, sucking in cold air? I would prefer not to go to the trouble of making up the intake box for my pod, but i will if its worthwhile (cant afford to buy 1) If any one wants that re-worded just ask, im not so smart :O
Also is it worth putting some custom or aftermarket exhaust headers on it? It has a 3 inch turbo back exhaust, but standard exhaust headers. Am i likely to get less lag or faster spool or moor KW out of em?
Thanks, sorry about the annoying questions but i have looked around and cant really find specific answers to my questions.
you don't have to make a full box for it. just 1 wall to stop the hot air getting to the pod. i have a pod and i have a duct coming up from the intercooler pipe hole (i have a front mount so i have an empty hole) and i'm going to put the factory cold air snorkel back on and just have it sitting on the pod, and just make a single wall up to stop the hot air. that way i will have 2 sources of cold air.
http://img456.imageshack.us/img456/9962/r32carsm2ph.jpg
So lets say i had it hooked up like that, coming off the turbo, i would then make a heat shield (out of aluminium) going diagonally from the [wheek arch] to the side of the pod filter to block off rising heat from the engine, and leave the back and front of the pod open, with my standard cold air intake in the same position
right? or wrong
Edited by 32thrasher
yeah sort of. i have the standard intake, i just have a pod where the airbox was. go here http://www.uniqueautosports.com.au/ and go into parts catalogue, skyline gts-t, engine. then most of the way down the page there is a UAS cold air box. the pod sits in that. basically all you need is the vertical wall.
thanks so far, but another annoying question, what do you mean, have the factory cold air intake sitting on top of my pod? Do you just mean have the factory cold air intake, inside of the partition, facing the pods general direction?
Thanks for your help, so far :ermm:
the yellow line is about where you would put the partition, and the green represnts the top half of the factory airbox and snorkel.
the pod is under the green bit.
Edited by mad082
i'm having one of those days too. you'd probably want to make the partition out of a heatsheilding material rather than aluminium. any metal will just absorb heat and won't work as well.
you can get stuff for exhaust shops that works really well, but it costs a bit. but if you could get your hands on some high temp plastic, or a square of fibreglass, that would be ideal.
i'm going to make mine out of firbeglass and then go the the wreckers and get an old bonnet lining and put that in there for extra heat protection. if you do make it out of alloy i'd do the same.
r32's dont have a snorkel on top of the airbox like an R33 ...
the cold air intake comes from behind the passenger headlight and comes out of the guard into the airbox..
so yeah, might wanna consider that
So all your saying is if you have a R33 like me just buy the UAS fibreglass cold air box and keep the standard snorkel is that it?? wouldnt that just be pointless??? The air from the snorkel would not reach the pod in the UAS box.
heyaz, i just installed 1 of these things ( yet to add a partition for cold air) into my 32 gts-t and wow. I didnt think it would make any difference but the difference is huge. I dont know if the sensor just inside the intake had a loose wire or what but i added the pod and now i get my turbo spooling at 2800 rpm instead of 3000 rpm and it holds boost almost to 6000rpm at which stage it drops boost, instead of dropping .2 bar the second it hits 5000 rpm.
Makes the car sound a like its got a BOV or something, the pod noise is really damn loud. (not sure if im to keen on it)
thx 4 ur guide mad
Edited by r32 gts-turbo
nahh, just a pod and made a partition out of 2 peices of aluminium with some heat obsorbing material in between (split pins to hold the 2 pieces of aluminium together) a bit dodgy :unsure:
i wasn't saying buy a UAS one and leave the stock snorkel on. 32 thrasher didn't understand what i meant about a partition. what i'm saying is put a partition up and leave the factory snorkel. if you buy a UAS box you wouldn't use the snorkel unless u cut a hole in the box to feed it into. the problem with the UAS boxes is that if you have a stock cooler or a cooler that uses both stock intersooler pipes, then the box doesn't get very much airflow to it, unless you start cutting holes.
and i didn't know r32s didn't have a snorkel.
Edited by mad082
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
