hi guys,
I got my gtr dyno'ed a couple of weeks ago, and was wondering if the power figure was normal.
Its early 89, no doubt 200k+ on the clock.
got 225HP at 8psi boost
only mods are Apexi pods (no heat sheild)
Fuel was caltex vortex (couldnt fill up on bp98 at the time)
Its got the stock exhaust, cat, and boost restrictor.
I havnt run a compression test or leakdown test yet, and it doesnt seem to be using up oil.
so is that figure someting to worry about, or is it normal for a car of that age?
Thanks
Steve
Edited by PHATR32
https://www.sau.com.au/forums/topic/117330-gtr-dyno-reading-low/
That sounds pretty good for a stock 200k+ km GTR. If the car was modified the it might be a different story. The figure is even better if you used a 4WD dyno as you get more drivetrain loss. I wouldn't worry too much about the actual power figure asy dynos always vary, your power & torque curves will tell more about the way your car is running.
Beer Baron: 225hp is about 168kw.
Edited by Quinny
yeah its 168kw, at the rear wheels.
i was just thinking about it last night, and it popped into my head that they are 206kw from factory form.
But then i just thought about it again a few mins ago (after a strong coffee) and remebered thats 206kw at the engine.
So therefore: drivetrain loss + 16 years of abuse + 200K = lower power reading?
did i just answer my own question?
steve
Edited by PHATR32
Looks good, nice solid power for such an aged car.
Ring Lumpy and ask him if he'll print you one with the AFR on it. Should still be in the computer.
You won't get a torque graph. Well you can but it won't be accurate, once you start running it through gearbox/diff etc the figures of the reading will mean nothing. all it will do is give you an idea where it's strong and where it isn't. Remember, to get an ACCURATE torque figure you need and engine dyno, once the gearbox diff/tyres come into the equation all it will give you is an ESTIMTAE of tractive effort.
Hope I've explained that clearly?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
