So last night I was on my bike and I was coming into mitchell from gunghalin along flemington road, and a guy exiting mitchell to turn onto flemington has just gone it, with speed and didnt even look. I was only doing about 30-40 as I was nearly into the corner, I swerved missed the car but went up the gutter got thrown from the bike and damaged the bike, not badly but it didnt have a busted headlight before did it??? THe guy goes up the road stops after about 100m, I think he didnt even realise but then yells out "you okay?" I say yeah and he takes off!!! Bastard If anyone sees a older guy, looks true bogan in a burgandy el-ef falcon wagon with the plates YAD 3 something give him hell. Geez I cant believe there are people like this in the world , gets me so cut, I am alright but its not the point it could have been 10 times worse really easily!!! End Rant!!!
that sucks although i dont think i like the idea of using my skyline as a battering ram i think mine will come off second best lol dodgy old falcon vs clean skyline...
i will be getting a bike soon and thats the sort of thing i dread
Jeez, Leigh you big bad a#se, I might see you on the road somewhere interstating.
I'll have to look for a fella with fingerless gloves and fringes on his jacket then??????...................lol
Must be something to do with the badass colour 'black' that we both have----good luck.
Really sorry to hear that mate, my friend Dee got her bike licence a month ago and 2 people have nearly ran her off the road, one on purpose. She hasnt hit anything or done any damage but she is worried about it now..
hehehehheh tridentt thats funny as sorry leigh but if i saw that.. i think i would find the closest thing to take a photo and laugh really hard (fingerless gloves and fringing hehe)
Just got it home, rode 4 hours from Sydney, at night, with fog, in the rain......smart? No!......bloody impressive effort? you fu**in bet!!!!!
Will post a thread tomorrow or something, right now I'm cold, aching and in need of a bloody long, bloody hot shower!....night.
CBR250's are awesome, ive just bought a new race prepped one for the 250 series in Vic
anyone wanna buy an 01 R6 trackie for $5500?
awesome??? uumm, maybe with an overbored 400cc engine it it. but 250's are too limp imo.
i ride this beast: http://www.skylinesaustralia.com/forums/in...showtopic=96873
just had my 8th & 9th knee surgery, so I really should be giving riding away.
dude, any bike that can be power wheelied from first into 4th and scrape gear selectors is good IMO, they are awesome for the track
and theres video proof of 4th gear wheelies (but he only kept it up for a second)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
