have you guys heard of royal purple or Amsoil? I heard they are really good better than mobil or motul.
Royal Purple engine oil costs a bomb, but in all the tests, power tests done by the magazines, which it was featured always came out on top, but it's real pricy and not available anywhere.
I chose 10W-30 Mobil 1 for it's availability as much as it's quality, as it's available from just about any Mobil servo.
Cheers, D
  • Replies 42
Are they any synthetics for Kendall?
Before i got my car tuned by race pace i was using Mobil1 15w-50 which is actually a ,motorbike's oil. Ben from racepace put in Castrol Edge 10w-60. I never liked Castrol. And when i called the Mobil Distributor and spoke to the lubricant specialist at mobil. He said that Mobil and Castrol oils works very differently.
If a car had been using castrol oil since new and had done 100,00km on the speedo and you switch to Mobil oils the engine will shit itself. Why?castraol oils does not absorb the carbons in the engine. Castrol oils actually leaves the carbon deposit in the engine so that the oil stays cleaner therefore better protection. Mobil oil actually absorbs more of the carbons therefore your engine is cleaner. (dont shoot me for this as im just repeating the lubricant specialists comments about castrol). Also when i spole to the Oz distributor for Royal purple (off the records he says) Castrol edge 10w-60 is not a true 10w-60. Irs actually more like 10w-45or 50 when its operating at high temp.
Mobil 1 came out with 15w-50 for cars now with added compund that reduces friction in it. I can get it at $72/5ltr drum.
If you guys are running high powered Rbs then i think you guys should use 15w-50 at the very least. At least thats wat i got the impression from Ben in Racepace but he preferes 10w-60 though.
I think i will be sticking with Mobil one although Amsoil is $75/5ltr srum+freight. Very tempting
Edited by stasis
Kendall make a synthetic oil as well. The Synthetic makes more power but has none of the protective properties of the mineral oil. It has a very high burn point (mineral) and this is the only convincing argument to go synthetic in the first place.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
