Whilst under the stagea this w/end i found a messy oil leak from maybe rear seal of g/box or plumbing 4 attessa. I put a spanner on oil feed line, retaining bolts and bleed nipple (all tight). Didn't, but will make time 2 check oils. Anyone had same problem?.
https://www.sau.com.au/forums/topic/117815-oil-leak/
Speedo cable o-ring or top boot seal for gearstick is also a common one.
https://www.sau.com.au/forums/topic/117815-oil-leak/#findComment-2166272
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
