Ive gotta lose some bulk **** as i am moving, i will probably add more items as i find them.
RB25DET Neo Complete - Runs but has blow by (Computer + loom + engine + all sensors including o2 + all piping + turbo + rwd conversion sump)
I am willing to split this up if most of it goes. - EOI
600x300x100 cooler in new condition - $200
Turbosmart BOV, i think its type 2, butterfly type $120
r33 turbo piping - $50
DVD/cd/mp3 player with remote - no lcd just analog and digital outputs $150
HKS Front Springs for r33 - $50
r33 std suspension & springs - $100
std r33 dump pipe - $30
std r32 GTR front pipe - $30
r32 GTR Stainless dumps - NEW - $offer
Sony speakers - High & midrange with brackets $40
Neo Turbo - busted - good for highflow - $50 ono
Alpine CD changer/stacker - $50
r33 sump - $50
complete front wiring loom for Neo - from computer to dash etc - $30
Neo Dash - good condition - $80
sub box, suit 2x8" - $10
std cooler for r33 - $10
ABS module - $100
series 1 r33 coilpack amp module - $50
Stagea 4wd auto box and tiptronic gearshift - $100
std r33 steering wheel - $20
All offers considered, more stuff to be added soon, email me for pics [email protected]
0404344855
https://www.sau.com.au/forums/topic/118120-garage-clean-up/
Interest in the
DVD/cd/mp3 player with remote - no lcd just analog and digital outputs $150 ?????? what model and anything wrong with it?
"and"
Sony speakers - High & midrange with brackets $40, please e-mail me the pictures [email protected]
Edited by sybrix
https://www.sau.com.au/forums/topic/118120-garage-clean-up/#findComment-2173217
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
