I have a neo rb25 in my r32 gtst. Bought it with it in already.The car was a bit rough in a few areas. First the exhaust was crap, so i put a 3'' under it highest flowed cat as possible.... :D Spit waste gate stainless dump pipe, already had a trust cooler on it. 450x300x100. Im running 8psi and it spun 205kw@ wheels.. How much boost can you run and torture these turbos?
I have done countless searches on the internet and have come up with a loss everytime....
Doe's anyone know where I can find specs?
Or doe's anyone have any that they wouldn't mind passing on?
I have to say I find the NEO 25 to be a completely different power compared to my old s1 25. It is alot smoother and seems to have alot more torque top end... :P
https://www.sau.com.au/forums/topic/118132-neo-rb25-specs/
My RB25 on my 34 runs up to 80kPa(~12psi) boost. Only power mods is a pod, everything else is factory std. Im a lil surprised too, either my stock boost gauge is out or ive got some factory freak that runs higher than normal boost. Ive read a no of threads on this topic n most seem to think a stock 34 should run 7-8psi boost max.
Im looking at getting a aftermarket boost gauge to confirm this before i start playing with boost.
https://www.sau.com.au/forums/topic/118132-neo-rb25-specs/#findComment-2175086
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
