i knwo he was trying to get some info from a supra forum, but couldn't get the pictures to work, never heard from him if he worked it out..
only thing i saw was him start the car and turning the TPS with his hand to make sure everything was working.. lol
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2180944
ive figured out what the wires on the q45 tps are,
does anyone know what the wires on the stock rb25det II are? colours and description
craved- i found my information from a supra forum 2, pretty useful
this is what i uncovered so far
on the q45 tps- plug that runs off the tps
Red is the 5 volt input wire
White is the TPS signal wire
Black is the sensor return wire
so i need to know-
1-what wires to match these to
2-also the second plug (wot) of the q45
cheers,
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2199451
try pauls site, see in the diagrams section there is a engine wiring diagram
http://members.dodo.com.au/paul/
see if you can decipher it.
lets us know how you go
craved, your a legend!
pauls site helped alot (cheers paul), so now i know all the wiring on the rb (WOT + TPS) and the tps of the Q45. but i still havent got the WOT diagram or wires of the q45
its a 3 pin plug which would include:
1,throttle valve switch(idle control point) IDLE
2,throttle opening output signal SIGNAL
3,throttle valve switch (power supply) FULL
ANY IDEAS PEOPLE?
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2205372
the plug on the tps body is for wot and idle.
take a multimeter and have at it, center pin is common ground for the two so from what i remember if the tps is face 'down' (brass bit down that is) then the idle is on the left of center and wot at the right of center...
i might have that reversed lol...
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2206245
  • 3 weeks later...
Here is the diagram guys.
Very simple
In the picture and diagram it illustrates the way it sits in the car attatched to the plenum which should be always upside down to suite the throttle cable layout but it all depends on the plenum.
But to under stand which way the vertical wires are on the plug.
So from top (bonnet side) to bottom (ground side) on the plug
Green
Black/White (Can also be just black)
Red
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2264339
hey guys, just a quick one, what throttle cable are you running with the q45 throttle and GReddy intake?
any help would be great
NutR33
awesome work SLIDE your a champion this needs to b a sticky, im still waiting for my damm greddy plenum autobarn screwing me around.........should b here in 2 weeks
btw slide just as nutr33 asked, r u using the standard throttle cable?
cheers,
fangz
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2266675
We had a custom one made up by a shop on the Gold Coast.
Sounds funny but most large Boat shops can make up throttle cables.
You just tell them the throttle cable length you want and how much inner and outer lenth you want for the sleve.
Wgich is what we did.
Some ENZED's also are able to do them.
https://www.sau.com.au/forums/topic/118484-q45-tb/#findComment-2270952
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
