Just purchased a Garrett GT3540 (GT35R) for my R33 GTST. pulling off the old HKS GT-RS turbo for some more power :nyaanyaa:. the turbo is rated at 700hp and i have it with a 0.82 rear housing so boost comes on reasonably early. Has anyone seen one of these on an R33 gtst?
Also motor is standard internals, only have bigger cams. Anyone else running 320+ rwkw on the standard motor? How long have you been doing this for?
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/
I had put one of these on my r33 , great choice. I wouldn't run it on a stock internals but thats just me being safe.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2184377
Im running a 35/40 .82ar on my 33, power fc, z32 afm,38mm external gate, pump injectors, fuel rail, plenum, zorst etc. 289KW on 16 psi. Standard internals. Cant run anymore boost (std coils) The tuner said it will get over 300KW easy with splitfire coils. Sorry cant find the dyno graph.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185526
my car has been making over 350 kw off the standard motor for about 5 months now
i have run a 10.8
and have done endless hours on the dyno
and i mean over 350 dyno passes
trying different pleniums,fuels,boost controllers,coils & different power between clutch fan and thermo fan
as long as you have a safe AFR and large flowing intercooler such as a garret core 600x300x100 it will last.If you have a lean AFR and Small intercooler 600x300x76 then it wont last as long.
with nitrous my car is making over 400 kw now
its making a total off 591 hp at the rears.Hasnt poped yet
i thought ill put these motors to the test
and they are pretty much bullet proof.
the problem with RB motors is if they detenate in top end revs or oil surge its the end of them.Always maintain good oil and Fuel
Edited by MR331307
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185608
I have a 3540 with .82 exh housing on my 33 and it's on full boost at about 4500rpm. On 15psi its making 306rwkw on standard internals (apart from cams).
Can easily make a lot more, but I dont want to break the motor just yet :P Running quite conservative on A/F ratio at 11.2 to stop it leaning out anywhere.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2185688
mr331307 ya makin 400kw with nos on a standard engine?? but i see ya car for sale and it has forgies ported head gtr rods the list goes on..thats not exactly standard man or is that a diffrent car???
sorry for hijackin ya thread boro but i might have to try a shot of nos if 400 is possible
Edited by thizzle
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2189473
Nah its the same car
just my car still has the standard motor in it
and the person who buys the car gets the Race motor i have built
Currently im running 18 psi in it with a 50 shot of gas and its made a total of 591 RWHP on my dyno. Inlet temps just under 40 degrees on the dyno sheet.
I have done that many things to this motor and it wont blow up lol
i am going to run 24 psi and 75 gas when i come out to see if i can run a 9 if it blows then the other motor goes in and ill run 28 psi and 100 shot of gas.I want to see if i can achieve a 9 on the standard motor.
the car is for sale so if some 1 wants it PM me and stop hijacking the post
Thanks Jason
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190344
And if you want dyno sheets of my car without nitrous
check ou t
MAX HP out of standard RB25 motor
Heaps of dickheads posting shit on the thread but bypass what they have said as they have never tried or done research in the making power out of these motors.
I thought i will give it a try and its lastest me over 5 months or so now and i dont mean grand ma driving
I drive it like i stole and and off my Videos on my site you can view it in the burnouts on limiter.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190367
im sure croat wont mind me askin questions were good mates..
mr 331307 i have read ya thread and if ya check i actually supported you when others cried bullshit..it just 400 is gettin a bit hard to swallow on pump fuel..was askin cuz as i might try a 50 shot and see how it goes..
have u opened the engine???
what brand is your dyno? keen to see your next result lol maybe youll hit 800hp
Edited by thizzle
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2190407
nah havent opened the engine yet as i quoted completely standard with 69000 kms on the clock.
if you are located in NSW i am more then happy to put the car on my dyno which is a dyno dynamics Shootout chassis dyno and show you the cars RWHP.I will also show you and take you for a drive to show you its on the pump fuel.
In total im making 500 HP on 18psi and 591 with 50 shot of nos on pump fuel & full exhaust.
i find that over 18 psi you will need pump fuel as there isnt enough octane to suit hi combusition & temps in the engine.
Im pretty sure you can watch the first stages of the car on the dyno from that site.I will upload the 10 sec pass soon as well as the 550 + dyno runs.
You will find that The Intercooler,The Tune & the Plenium all make a big difference in the motors Power.I have done alot of reasearch and have found what works and what doesnt.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191329
I made over 330rwkw using fuel on stock coils for over 6 months without an issue.
There are just some places will have you believe that you "need" to upgrade just so they can make a fast buck.
Just making sure ya werent being lead on :)
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191750
Very true
i have dynod a car that made 300 KW with standard coils and its still going
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191761
They are well overdue for replacement, but ill get a few more months outta them.
Yeah true that, they always trying to sell you something you dont need. I learnt my lesson the hard way with that.
The tuner only tuned cars, he does no workshop work, so i knew that he wasnt trying to rip me off.
Cheers anyways mate.
https://www.sau.com.au/forums/topic/118647-garrett-gt35r/#findComment-2191827
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
