Hey guys,
Im looking at selling my RB26/30 with custom stainless exhaust manifold and 63mm wastegate. The engine is previously from Mighty6.
If i dont get what im after ill continue my project.
Specs of the engine are as follows:
RB30 Bottom end
Cryoed crank
Arp rod bolts and head studs
Argo rods
Custom JE Pistons with with 22mm Gudgeon pins and lowered ring lands
3/4 grout filled block
copper head gasket
RB26 Head
Heavily ported by headsense
Heavy duty valve springs
HKS Cams
Inlet plenum
105mm throttle body
Direct port NOS system (including soleniods and 10 pound bottle)
Rochester 1240cc injectors
Additional injector rail
Custom fuel rail
Custom high mount exhaust manifold with T6 flange
Engine built to handle 1200HP by Hardcore Racing components. Would consider seperating parts but only in the groups as set up above.
Im looking for $12,000 negotiable for the Lot
PM me if interested,
or call 0404212391 (may not answer due to work so leave me an sms and ill get back to you)
Cheers,
Scott
Edited by Shwartz_sticker
https://www.sau.com.au/forums/topic/118964-fs-rb2630-built-to-handle-1200hp/
Engine has previously pulled 784rwhp without NOS and 9.3second quarter
how many kays/runs has engine done since last rebuild.
can you confirm if comp test/leak down test/general check has been done recently-ie any sort of assurance available as to condition.
apparently the fact it has 3/4 grout fill renders it not favourable for my circuit racing purposes. thanks for the reponse but i have just purchased PVL's..
I bought it off Goran (the guy who had it in the VL). I have a fair few personal "issues" at the moment and im thinking off selling. If i dont get what i want ill still keep it.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
