Hey guys,
Im looking at selling my RB26/30 with custom stainless exhaust manifold and 63mm wastegate. The engine is previously from Mighty6.
If i dont get what im after ill continue my project.
Specs of the engine are as follows:
RB30 Bottom end
Cryoed crank
Arp rod bolts and head studs
Argo rods
Custom JE Pistons with with 22mm Gudgeon pins and lowered ring lands
3/4 grout filled block
copper head gasket
RB26 Head
Heavily ported by headsense
Heavy duty valve springs
HKS Cams
Inlet plenum
105mm throttle body
Direct port NOS system (including soleniods and 10 pound bottle)
Rochester 1240cc injectors
Additional injector rail
Custom fuel rail
Custom high mount exhaust manifold with T6 flange
Engine built to handle 1200HP by Hardcore Racing components. Would consider seperating parts but only in the groups as set up above.
Im looking for $12,000 negotiable for the Lot
PM me if interested,
or call 0404212391 (may not answer due to work so leave me an sms and ill get back to you)
Cheers,
Scott
Edited by Shwartz_sticker
https://www.sau.com.au/forums/topic/118964-fs-rb2630-built-to-handle-1200hp/
Engine has previously pulled 784rwhp without NOS and 9.3second quarter
how many kays/runs has engine done since last rebuild.
can you confirm if comp test/leak down test/general check has been done recently-ie any sort of assurance available as to condition.
apparently the fact it has 3/4 grout fill renders it not favourable for my circuit racing purposes. thanks for the reponse but i have just purchased PVL's..
I bought it off Goran (the guy who had it in the VL). I have a fair few personal "issues" at the moment and im thinking off selling. If i dont get what i want ill still keep it.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
