I have a problem with my R33 tail-lights (and I know I'm not the only one) where during the brake pedal being pressed, one side lights up less than the other - they still light up but it seems the top part of the problematic tail-lights are very dim.
Anyone got any clue as to how to fix it?
Also, how readily available are replacement bulbs?
Is there one bulb per tail-light unit (eg 2 total) or one per light (eg 4 total)?
https://www.sau.com.au/forums/topic/119007-tail-light-trouble/
you'll find that if you ever need to replace brake light globes, to work properly you need to replace ALL with exactly the same brand otherwise you'll get slight voltage difference between the new and old globes, gives you the problem you have.
if not, maybe the lenses in the tail lights are dirty. or possibly one tail light is newer than the other and faded less.
Sometimes the globes deposit a silver coat on the inside of the glass - severely cuts down on the ability of the light to get out.
Pull the globes and replace if necessary.
The other possible cause is a bad earth on one side.
Yeah agreed. Multimeter onto each socket to test ground and power. Compare it like you would a compression test.
Then, replace ALL brakelight globes (4, twin element as mentioned) with some new, clear, good quality globes. (prolly cost you less than $20). Pay attention to the wattage of the ones that come out. Go higher if you like, or just match all the new ones with the same rating.
Don't touch the glass. Use a tissue or something. Grease on a globe helps kill it.
Clean the contacts inside the globe holder if they look nasty. With the lights off, there should be no power to the sockets, so you can wrap a bit of steel wool around your finger and then stick it in there and give it a good scraping. Blow on it afterwards to get the dust/rust/corrosion out.
That last sentence sounded very sus! Anyway. Good luck!
i think i saw ur car around prymont u have the new led tailights,there cool. I also have them but when i was installing them i followed the wiring from the original lights and my brake lights werent working at all .Anyway i tryed every combo gave up took it to auto electrcian cost$40. Unless u have the tools ie amp meter etc. its pretty confusing.But for the trouble the lights are awesome!
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
