hey guys... my baby is up for grabs!
fitted with plenty of extra's.
- apexi d-jetro ecu fitted and running 14psi
- bilstein suspension
- front mount intercooler (hybrid gt)
- apexi air filter
- front and rear nismo strut tower braces
- 18inch roh drift r's with 98% eagle f1's
- motor replacement. car had a failure with the ecu, and as a result a motor with 30k was replaced into the car.
- full xforce exhaust from turbo
- walbrough fuel pump
car is at this price with mods. optional price without ecu can be enquired.
car is going due to purchase of house. car photo's will be up within days.
car is a dream to drive, and just had air con regassed adn replaced entire system. car is in a1 condition and is only being sold to afford deposit.
price has been dropped.... car must go.. its house time! 29k ono
gime a buzz
0401855747
looking for a r32 or a 180... buying a house so would consider a swap, plus cash my way!
Edited by BENRYS
https://www.sau.com.au/forums/topic/119110-jap-spec-s15/
Hey Benrys, nice white S15 you got there. Saw you along Princess Hwy tonight after we passby the poor 180 that hit the tree along the road. Was trying to say hi to you but guess you turned around and talked to your girl?
Guys don't miss this opportunity, this S15 is in mint condition. Good luck for the sale :(
https://www.sau.com.au/forums/topic/119110-jap-spec-s15/#findComment-2206002
Guys don't miss this opportunity, this S15 is in mint condition. Good luck for the sale :laugh:
yeah thanks, thats the missus.
car is still up for sale guys.... price is negotiable, without mods... let me know what u think
https://www.sau.com.au/forums/topic/119110-jap-spec-s15/#findComment-2236376
  • 3 weeks later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
