i was driving along wanneroo road with my mate in his r32 gtr, we approached the lights next to tuart hill maccas . As we pull up i notice the car inb the left lane is a magna... but wait it gets better it must have been some kind of super magna because it had a gtr sticker on the rear of the car.:bahaha:
i was laughing my arse off... we pulled next to this magna at the next set of lights and a stuck my head out the window and stated " Oi mate whats the deal with the GTR sticker" his response was " Oh its a factory extra, its a done up version of the magnas."
:bahaha: :bahaha: :bahaha:
i then said to him oi mate look what car your driving now have a look at this lovely piece of machinery...this is a gtr
the lights turned green and we left him in a cloud of smoke lol
some people are just f#cken stupid....
i found it very amusing though
https://www.sau.com.au/forums/topic/11913-magna-gtr-what-the/
AHAHAHAAHAAHHAAH!!:D :bahaha: :)
Thats what i like to hear!!! why people do that I have no idea...
Yeah the GTR Magna Rb26 twin turbo 4wd!! Bwahaahah!!
That has put a smlie on my face, Ive always wanted to do that but never manged to find cars while the driver is in it and on a private road of course.
the funniest i have seen is a suzuki swift like 1976 model or somthing old like that with GTR stickers on the back!! bwahahah! what an ass clown!
I think its even funny when you see a GTR badge on a non turbo skyline (& oh i saw heaps of those while looking for my baby)
People just laugh at you - screams "try hard"
Ahhh the old magna eh - a ralliart badge didnt quite cut it so they had to stick a GTR badge on there as well haha
first a WRX now a Magna - how low can he go haha! Oh well people will undrstand your taste in music if you drive a magna it'll be like "what the hell is that noise ...oh look its coming out of the magna thats ok then he was obviously born with bad taste"
hehe :(
Yeah see your a smart man because your Magna would of lost a lot more money!
Driven Veradas and Sports many a time they are what they are Mitsubishis. Ok they arent all that bad but they are hardly a sports car!
Why not just go the ultimate try hard mitsubishi.. the all new ralliart vtec gtr hks apexi nizmo lancer, running 13" rubber with extra soft toys on the shelf.. i hear the badges are good for at least an extra 50kW at the wheels.. and the toys are only for the hardcore... :(
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
