Hey guys
basically i need the following parts for an r32 GTR
i need:
steering wheel - gtst or gtr
GTR drivers seat
GTR centre guages
Center dash surround with asytray
stock gtr clutch
yeah so anyone with these or whereabouts
let me know
I have bopth a genuine gtr steering wheel and a clutch kit which is basically brand new
email me on [email protected] if you are interested
