help with plate
S4TEEN - I like or 200SXY but i wouldnt be surprised if thats already taken and if it hasnt it should be :( But i think you would be mroe likely to put that on a chicks car.
Hey if you look in some car mags - you can steal ideas off the eastern staters plates. I opened up a car mag one day saw my NIZMO plates sitting there on a 200SX - spewin copycat! haha but then thought to myself if your actually looking for somethin sweeet to put on a number plate wouldnt be bad place to start getting ideas.
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-210900
Originally posted by adam 32
i saw an R33 today with plates
extr33m. now i know this is 1 persons opinion but why would you bother with personalised plates? i just think this attracts unneccessary attention to your car.
I got mine for the shows dude, i used to like my gov plates because ion order for them to fit i had to bend the sides so if a camera ever flashed they could hardly see the last number. Now though with the new plates ( SLY 33 ) if i get flash i get a fine which is fair enough.
IN the shows EVERYONE has private plates and i really liked the one I have i thought it kinda suits the car... low and sleek so i though of sly. I was never much for private plates but i do like them even though as you said it does draw unwanted attention, just have to be extra careful where i drive and park from now on. :P
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-212596
each to their own, and if you want private plates then go for it. but i kow of a few guys with them and they hate them - purely because of the attention it gets. whether it be in a carpark or drunken idiots. a skyline with a private plate is going to stick out more an attract the 'undesirables'
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-212610
Originally posted by MODADDIE
thanks everyone i think i am going to go with   "S4TEEN"   plate..
i will decide tomorrow at work when i finish filling out the form, i called licensing today and its still available...
anyone feel free to use "4PLNCHXS"
Ahh feel free to make fun of me.... I am usually pretty good with plates but I cant work out what the hell 4PLNCHXS is meant to mean??? Maybe its too early in the morning or something??? :P
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-213876
    • Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
