http://cgi.ebay.com.au/NEW-SKYLINE-R32-R33...1QQcmdZViewItem
Why not get a split dump like that one? supposed to be better i think.
so not far then, i'll grab one of the fullli hektik qml toyota carolllas and we'll go do some skids somewhere lol
looks neat. Does it come with gaskets??
nah no gaskets. just like that. butil just get the exhuast shop to put wem on when i get it installed, i tried to undo the front pipe on my exhuast on friday at work, but it was locked on tight, so il just get the exhuast shop to do it for me, i didnt really wanna brake any studs off or anything while i was at work.
yeah i lookedat them aswell, but after i talk4ed to the guy at the exhuast shop, he said they are good, but he has seen a few split round the welds from heat and stuff, and bcoz they have more welds on them, its more likely to happen than on the one i got so i just went with the safer option.
I've never seen a v35 in the flesh..
/insert rant about migrane headaches and how they suck right now :)
il show u one if there is still one up here when u come up (if u havent seen one before hand)
i know where there is a few actually.... just hope they are still where i saw them.
i dunno, arent they non turbos... i couldnt live without my turbo
yeah they are, but they are a nice car, leather 4 seater in the 350GT coupe but it would have to be a manual.
Available with the same 3.5L VQ35DE (NEO) powerplant as the Nissan 350Z, and pushing out 272 ps (200.06 kw) @ 6000 rpm and 36.0 kg/m (353.04 Nm) of torque @ 4800 rpm, the new V35 Skyline is capable of 0-100 in about 6 seconds.
There is even a 4-door performance version for those wanting 4-doors with performance, and if that is still not enough there is a twin turbo kit available for some SERIOUS power and definite street cred.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
