yeah im gonna keep the stocko one, but il just wanna geta hi flow one to replace the standard one anyway. i just wanna keep it all legal. i mean really im not at the point withthe car that the flow is gonna be affected that much with a hi flow cat there or bash out one. it doesnt really matter to me.
haha thats gold
i must ask, y do you want the entire exhaust system stainless? i mean its not like itll be seen at all
well the car came with a kakimoto cat back stainless exhuast on it, and now i have just got a front pipe and dump pipe that are stainless also, so all i have to get now is a cat, so why not just make it stainless aswell. to finish off the exhuast
I had no choice for my exhaust modifications.. Andrew had the car one day and came to pick me up from work and it was like 10 times louder.
yeah i have seen ppl put a straight thru pipe into a cat and weld it on so it looks like a cats there. im just trying to think how different it will sound with a fullsystem. so far ive managed to get away with thefront pipe and dump pipe all in stainless for $200
fair point
i picked up my new bottom end today :)
will be pulling out the 26 tomorrow and pull the head off to see what actually let go in it. then the 26 head and 30 bottom end are off to JHH next saturday to be built (fingers crossed nothing goes wrong)
if all goes to plan itll be back on the road in 3 weeks time, making some big numbers ;)
Is it worth spending that much money though on something that will do the same thing as something cheaper?
Is there really any benefit in getting a stainless one? Is it less restrictive?... Gains more power?... Not much difference at all.. just looks shiney?
fair point
so did u break the GTR already?? what happened??
id say there is no difference between stainless and mild steel, it just wont rust out, but since i have the system all the way from turbo to bumper in stainless, why not just get a cat to go with it. plus if i got one without a flange, i dunno if they can weld stainless to mild steel or not?? im not sure on that one.....
yep broke a few weeks ago whilst i was going to go for a drive with ben & dale
starting knocking at the toowong roundabout, turned around and made it home, knocks like crazy now though. we think its bearing related, find out for sure tomorrow :)
managed to pick up a recently rebuilt (200kms on it hone marks in bores still present) 30 bottom end with forged pistons (20 thou over) n1 oil pump, for $650 hehehe
so are they gonna bore it out then put over sized pistons in it???
nah thats already been done, just need forged rods, decent bearings. heads getting ported, exhaust side ports are getting re-profiled, whole thing balanced, sump being modified with a trust enlarged sump, oil galleries being fixed up appropriately for track work etc etc
sounds like your gonna spend a bit of cash on it then...... its hould be mean :)
yeh it should pull pretty good ;)
i only brought the stocko engine onto boost twice! i drove it back from newcastle off boost the whole way caus the clutch was stuffed that bad, then after putting the clutch in i smacked it side on into a gutter bending the left rear control arm, then the sat i got that fixed the engine let go
going to leave the stock turbos on for awhile and see what power i can get out of them, then i'll go the gtrs's :P
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
