Planning bucks party :) .....
I dont know what this invoves but i have a strange feeling that my buddies mean to "Test" the varities of products that brissi has to offer. :D
I cant drive yet so for now i'm just participating in these forums, he he he sign up when i get some money. and then will go out when my baby has all the work done to her finished. :D
would love to but dont have a lincence ATM. he he he with so much going on in the media about police craking down on hoons i dont think i will risk it and drive up there. but as soon as i can i will be attending EVERYTHING!!! HA HA HA then you 'll with you never meet me!! :D
yup. me too *nods*
I'm at work and the car is all fixed now. It turns out they had done all the work on getting it tuned, but the map didn't upload properly at the end of it all, so we were driving around on, what was esentially, an untuned car, with all new bits! But anyway, it's all done now. Yippee!!!
I haven't had a random story to tell for ages! Probably because I haven't DONE anything stupid in ages. And that's probably because I haven't had ALCOHOL in ages... no wait... that's a lie!
Last Friday I got a message from one of Andy's mates asking if we wanted to go for after work drinkies in the mall. So in I go, and after the shite week i'd had, I thought i'd drown my sorrows with a few vodkas. Well... a few turned into 9. And by 7pm I was staggering down the mall to do some shopping. NOT a good idea :mad:
At home, into bed. Well, not without first waking the entire apartment block up with my drunken ramblings and giggling and carying on. Eventually I passed out (around 9.30pm) and woke up at 11 with one HELL of a stomach ache, and proceeded to vomit all over the bathroom until midnight, when I flopped back into bed. Woke up nice and early Saturday morning feeling FAB, but with a very VERY sore back. I remember now, there was a reason I was not to drink... something to do with my kidneys :laugh::D
So does it go better now?
Don't know. According to Andy, yes.
can you guys and gals recomend anywhere good for a bucks night? doesn't have to have to be smutty, i'm sure well end up at a strip joint buy the end of the night. :laugh:
Ummm... I've been to a couple hens nights now, and I know they'd be vastly different, but one place that always stands out is zenbar. Go there to start, have a feed, and they have decently priced drinks too. http://www.zenbar.com.au/
Chill on Queen is a personal fave of mine, simply because they have SO MUCH VODKA!!! http://www.chillonqueen.com/
Other than that, any pub is good to run amok in :D
I cant drink for a few months, glandular fever sucks!
And last day of holidays.......
:mad: *holds hands in air* nooooooooooooooooooooooooooo
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
