SAu stickers...you got me started now :D
Been trying to get a decent sample for weeks now...first the people you talk to don't actually listen/read what you ask for, so the sample is wrong.
Then you try for another week to get a second sample, which of course is still wrong.
Then you try to actually get a price for these things out of the company, who say "we can't issue a quote until we know how many stickers can be printed per metre of sticker material"
GRRRR hopefully a new sample will be delivered today, all vinyl layered cut-out...then I can see if they suit and then I can get them printed (which I'm sure I'll be waiting a couple more weeks for) :D
Why are businesses so slack regarding the small jobs? I really think its because we are not spending a heap of money. But my argument is if all the small jobs went elsewhere, a business would soon close...
post in the events thread ppl.
this is purly for spamming!!!!!
he he he
:D
just joking do whatever you want :(
30 here i come!!!
see this is where you are not going to make your 30. the main reason being u dont split up your posts. your previous post should have been made up of these individual posts
1)
2)
3)
he he he
4)
:D
5)
just joking do whatever you want :P
6)
30 here i come!!!
Soon you will learn my boy :D
Karen New SAU stickers? or same as the current ones?
They'll be like the original ones, where the AU and the AUSTRALIA will be in silver, and the sticker will be nicely layered (if all goes to plan). They'll be the same size as the existing ones.
The last batch (which is the ones you would have Bryn) were not correct, in that the AUSTRALIA was black and the AU colour looked crap...but they had already been paid for so they had to get used unfortunately.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
