Shane...I have a purple engine as of sunday aswell!
engine bay or the engine covers? and is the purple a plain purple, or is it Lilac Pearl, caus thats what my engine bay is. and my engine covers are Ford Blueprint Blue, acompanied with polished bits everywhere :laugh:
Ahhh ours will be opposite
Mine is blue engine bay with purple engine covers..and it is some kind of pearl, I think pics are coming soon
Sif copy the purple engine craze :D
Hmmm....
Andy i think you missed my point........
so let me remind you.......
*asks inocently*
What cha doin next week end?
can i "borrow your 32"? i'll bring it back in good condition all clean and with a full tank. I promise :)!
:laugh:
Hmmm....
*asks inocently*
can i "borrow your 32"? i'll bring it back in good condition all clean and with a full tank. I promise :D!
:laugh:
Gotcha
Nien, The car will be at indy with me
lol u tool...i still reckon u'll struggle to get it all done in the one day. cams in, cam gears in, harmonic balancer on, timing belt on, then gotta set the timing, plenum on, manifold on, turbo on. big list isnt it andy :laugh:
The engine is complete as in it runs..it doesnt look like the pic now so most of that list is done what I should have said is "this is what the colour really looks like)
All that has to happen is swap the cams and change the turbo and injectors
Just get my money ready biatch
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
