already had one of them
over them the week i had it.
never again!
well your choice....
i've driven my bros skyline before not bad....
Its all a matter of prefreance.........
any way.......
talking about my bro.......
Karen he's not gonna be able to pay for a few weeks yet....
Burnt out his cluch so its now down a Ivan's shop (cant rember the name of the shop but its down near Moss street, he's an importer but also does some fitting,) getting a new brass button and lightend fly wheel, cost him $900 so has no money for the next 3 weeks :(
HA HA HA
there is a major storm on its way and damm its gettin dark already here in the cbd.
however, hopin that the miss indy finals outlay is as follows -
stage contains no roof or cover for the girls to strut their gear on.
the seating area of guest/patrons contains a roof/cover.
therefore, girls getting wet *ohhhhh yeh!!!!!* and patrons/guest (thats me) remain dry.
what a schweet idea!
be prepared to listen to his whinging about that button clutch :(
but that's a pretty awesome price lee! my clutch alone was more than that! :)
i need to order a new clutch soon,
he he he asking dan to do a rebuild soon and thought i should do the cluch as well while the engins out,
but i dont know what to chose,
which one do you reckon?
http://www.nissansilvia.com/forums/5-Butto...33-t121382.html
I'd go the street clutch....unless you like going to the chiro to keep getting your neck put back in.
Hey Shane you going to have you R back on the road for the annual cruise?
who knows. depends when it is.
seeing as ur going rebuild, get urself a decent clutch:
Jim Berry
3847 9999
I got his 'Full Monty' which is his top of the line clutch and its rated at 1000+HP, but u wont need anything near that.
but there's only like a $90 diffrence
he he he
but yeah Linh wont eva be able to drive it again if i get the button,
and organic is just like the ones we have in our car normally right?
You might find that the pressure plate with that more expensive kit is only rated to 1050kg (2315lb) and it might give a light pedal feel still, as it's not very heavy. How ever, with a low rated pressure plate & aggressive clutch face (button), you wont get the same clamp force as with a heavier pressure plate with a tamer clutch face (organic mix). My clutch has a 1633kg (3600lb) pressure plate with a carbotics (carbon, steel & others mix).
Give jim a ring and have a yarn with him.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
