got any reason why u dont like them? i've had no problems what so ever, and the speeds are fast, no dropouts etc...plus telstra is going down the plughole
optus run all the old network equipment from their overseas office.
they've not upgraded any of it in a while since they set it all up.
telstra on the other hand have a major deal with the big players including cisco.
they've recently just upgraded most of their exchanges for cable in launch of their new braodband network they are about to release that'll be apart of the 3g network.
SHHHH. no one is to know about this. :P
interesting...so what are the speeds going to be like? is it going to be reliable? what sort of cost are we looking at?
the US have had T3, T2, & T1 for years, and we're just getting T3 now, quite sad really
America is practically the backbone of the whole internet.
They can afford to sell t1-3 links for $60-$80USD a month to people though.
Unfortantly, we have the degrading pipeline link between countries where we actually suck the bandwidth from.
links will be faster, prices will remain the same if not, only go up by probably $10 or somethin like that.
our telstra wholesale rep didnt give me much info except for wat i said now and before.
And what happens if you go over the 7G?
either they stop your internet (doubtful) or they cap you to a really slow connection like at dialup speed (so they say it is but really, its half the speed of dialup).
OR.
they charge you for extra bandwidth you use and still stay at the same speed you usually get.
Hey John, I really admire you in taking on the qld police with that stupid copper who gave you those defects, STICK IT TO THE MAN DUDE! POWAH TO TEH PEOPLE! FIGHT TEH POWAH!
hehe, thanks dude.
goin to take a while to go through the process of doin this
but as they say - things come to those who wait.
just got to take all this step by step and get my fines out of the way
which will then allow me to move onto the next step of showing the next judge that the fines i received from this cop shows that cops like this one are clearly handing out fines for no proper/real reason and that either
a) the law should be taken away from the police in handing out defect notices
or
b) lower the power of this law to police in handing out defect fines to cars that are defected in terms of bald tyres, lights not working, etc etc.
stripping this power will become a victory point for us "hoons" against the fight we have with the police.
g'day andy, wats crappenin?
Narting much!
You wouldnt happen to have a spare S1 R33 ignitor would you :P This whole swapping the good one between cars is getting annoying lol
Morning Shane, Andy. *tips at*
Howdy
That is some funny shite John!! And being in Bathurst they probably had a line 10 deep for the position!!!!!
SIF bathurst is a sausage fest, you would be lucky to find 10 women on the top of the mountain
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
