Just found out how to get a free bottle of coke.
OR
go half and half in the cost of 1 bottle of coke with a friend.
http://www.break.com/index/how_to_get_a_free_coke.html
Yeah been on google vide for a good 8mths now :)
Also be sure to remove the links, otherwise you will get in trouble as these sorts of vids that relate to SAu members (club or fourm) doing illegal things on public roads.
I should know, I got in trouble for it enough :)
the first one was on crappy unsealed road so thats why it was only a short one, and the 2nd one, a truck came across the bridge (200m away) towards us when i just got started, was quite unimpressed ;)
yeh im not silly, it'll be as if nothing was there in the first place :)
shane those vids have huge green words on them...............
i dont want to see your old boat i want to see the new one!!!
man your car is taking foreva you'll be done bythe time i'll be done........
yeh the program i used to make the file smaller did that (was only freeware, blasted thing) but i truely did love that car :(
Well the engine has been all finshed minus the sump for 8 weeks now! but as someone once said to me, 'going custom or building anything like mine u gotta expect delays and timeframes to blowout'. I'm sending the CAD file to a laser cutter tomorrow, and should have the plate mid next week.
need someone to come up with a few million $$s and build a building right next to mine to block out the sun.
when air cond. goes down in this building, it gets pretty hot i noticed.
so, blockin the afternoon sun out will resolve the issue of heat in here when there is no air cond.
ha ha ha
cheap labour from ova seas......
+ red Bull/V
+ Borrocca
= 4months wit 50% savings
ha ha ha ;)
smart idea.... you go find some backyard cheap imported ppl and i'll start on the design (1 office per level) and we'll get shane to organise the v and redbull stuff.
in no time, we'll have our investiment paid back.
you could have a indian call center to answer all the calls
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
