Me thinks you guys should take this somewhere else.
Andy he is busy. He is actually a old mate of my dads, they used to race RC boats togeather. He is very anal with everything that he does and it is always has been that way.
Edited by SLO-89
yeh i could hey, f**k yeh pick up some 14 yo old broad minded persons root em then toss em your way?? although rape isnt my thing John... but we ( me and my gf, and the 2 other chicks u tryed to do it to ) will all agree that its ur style.. if u have anything further to say mate take it to PM
Hey Bunta!
Hello! :(
Ahh I see! I would love one! But yeah I have no time I need it fixed by tomorrow!
the std one (i think they are a bit better than the gts-t ones)
i also have 2 thermostats if its ur thermostat thats stuffed
Cool Thanks heaps for that, I will let you know! I have a R33GTST one lined up (Hopefully it fits) My thermostat shouldnt be playing up I have a newish nismo one! :( Or I could just try flushing my current one BAH to much to do in too little time!
All must be done before the tune on Monday night!
sounds like a whole wknd job is on the agenda
crack of dawn on saturday and finish up last sunday night :sick:
drink heaps of V!!! found it to work like a treat
well get ur tools out, stop being a skirt and get stuck in :(
It is on the cards for tonight!
If the R33 radiator fits it is a really quick job like an hour or less........if it fits
A flush shouldnt take too long either, Just need to decide what way to go!
:D John your a bad bad man
ha ha ha
John = :sick:
ha ha ha
Eddie i feel for you man i wouldn't want John trying to rape me either :(
Im glad it sounds good......are you glad u didnt buy some cheap unit like u wanted too
I never wanted to get a real cheap one - i thought the $500 budget was quite reasonable! anyways i only spent $550 ..ebay FTW ! one bizzare option pioneer decided was useful was a tacho, somehow it knows my rpm without any inputs...its reasonably accurate too! guess they had to keep the riceboys happy :happy:
Engage it doesnt seem to be working out for you here maybe its best that you stick with other forums
aww lee whats wrong with a few shit stirrers? need something to liven up whoretown these days
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
