aww lee whats wrong with a few shit stirrers? need something to liven up whoretown these days
“Whenever you're in conflict with someone, there is one factor that can make the difference between damaging your relationship and deepening it. That factor is attitude.” - in otherwords leave before everyone hates him becuase his attitude isnt inline with most other SAU members
Hey guys, I just noticed something.
This is the QLD SPAM _ TOWN, so posts in here are not meant to be taken seriously.
I also noticed forum rule dictate everyone must treat others with respect and that no form of slander or attacks on others will be tolerated.
Just something I saw popup.
Behave please.
It is on the cards for tonight!
If the R33 radiator fits it is a really quick job like an hour or less........if it fits
A flush shouldnt take too long either, Just need to decide what way to go!
I chose the flush option...it worked, kinda
what colour was the stuff that came out? was it brown at all? could be corroded inside. go give it a fang and watch the temp
and good morning :D
It was mostly green with a little bit of brown it wasnt too bad at all, I think the clutch fan is broken too
Either way it is good enough to get to Sydney and I will decide what to do there!
still a loser i see Lee?
Mate......
dont be disin Lee
i got sum advice for you!!!
"STOP RAPE!!! say Yes!!" ;)
ha ha ha
*seriously i dont condone rape :O
I swear!! :D:D Honest to god!!
:) he he he Sif you guys believe me.....
oh and Good morning ladies.....
John dont make me flip you ova Brokeback Mountain Styles!!! :huh:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
