Seriously though John, are you that stupid that you cant just get over it and leave it alone.
yo have written there hahahaha after lets rape each other, hows that funny????
just drop it and leave it, or do it in another whoretown....
dude, u have no humerous bone.
oh im sorry john, i guess the topic of rape isnt something i find funny...
grow up.
* end of this discussion. *
why my PM;s Shane?
well if u dont find it so funny, how about you have a go at someone who's willing to slander someone who raping chicks that is clearly not true.
though i dont have to prove myself on this forum for the pure fact that those that know me well enough know the true facts.
but like you said, its not a funny matter at all which therefore, in your case since you wouldnt have a clue who i am would take the matter of someone calling me a rapist funny.
grow up.
why my PM;s Shane?
caus ur an angry young man and I TOLD YOU TO :sick:
P.S joking, all is explained :verymad:
i dont find you being called rapist funny at all, i got made as you both moved on, he posts a thing unrelated to to, and you jumped on his ass....
everyone has the right to use whoretown.
like i said im not taking sides about the rape. im just saying get over it and move on
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
