HANDBAGS
Have you ever noticed gals who sit their handbags on public toilet floors -
then go directly to their dining tables and set it on the table? Happens a
lot!
It's not always the 'restaurant food' that causes stomach distress.
Sometimes "what you don't know 'will' hurt you"!
Read on...
Mum got so upset when guests came in the door and plopped their handbags
down on the counter where she was cooking or setting up food. She always
said that handbags are really dirty, because of where they have been.
Smart Mum!!!
It's something just about every woman carries with them. While we may know
what's inside our handbags, do you have any idea what's on the outside?
Shauna Lake put handbags to the test - for bacteria - with surprising
results. You may think twice about where you put your handbag.
Women carry handbags everywhere; from the office to public toilets to the
floor of the car. Most women won't be caught without their handbags, but
did you ever stop to think about where your handbag goes during the day?
"I drive a school bus, so my handbag has been on the floor of the bus a
lot," says one woman. "On the floor of my car, and in toilets."
We decided to find out if handbags harbour a lot of bacteria. We learned
how to test them at Nelson Laboratories in Salt Lake, and then we set out
to test the average woman's handbag.
Most of the ladies we talked to told us they wouldn't be surprised if their
handbags were at least a little bit dirty. It turns out handbags are so
surprisingly dirty, even the microbiologist who tested them was shocked.
Microbiologist Amy Karen of Nelson Labs says nearly all of the handbags
tested were not only high in bacteria, but high in harmful kinds of
bacteria. Pseudomonas can cause eye infections, staphylococcus aurous can
cause serious skin infections, and salmonella and e-coli found on the
handbags could make people very sick.
In one sampling, four of five handbags tested positive for salmonella, and
that's not the worst of it. "There is faecal contamination on the handbags,"
says Amy.
Leather or vinyl handbags tended to be cleaner than cloth handbags, and
lifestyle seemed to play a role.
People with kids tended to have dirtier handbags than those without, with
one exception. The handbag of one single woman who frequented nightclubs
had one of the worst contaminations of all.
"Some type of faeces, or possibly vomit" says Amy.
So the moral of this story - your handbag won't kill you, but it does have
the potential to make you very sick if you keep it on places where you eat.
Use hooks to hang your handbag at home and in toilets, and don't put it on
your desk, a restaurant table, or on your kitchen countertop.
Experts say you should think of your handbag the same way you would a pair
of shoes. "If you think about putting a pair of shoes onto your
countertops, that's the same thing you're doing when you put your handbag
on the countertops" - your handbag has gone where individuals before you
have sneezed, coughed, spat, urinated, emptied bowels, etc!
Wash cloth handbags and use leather cleaner to clean the bottom of leather
handbags.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
