I also remember a time when most people in the club didnt want a certain member to be in the club...it is funny how quickly people forget
nope, not forgotten. but when someone makes racist comments, verbal voilence towards many people, abuse, threats and harasement into a public forum towards members, can only see where things may lead on cruises.
Why would high rollers be pissed? You can be a member of both, they were actually really nice guys and girls when we were next to them at autosalon
that he pissed them off and now they are doggin him........
just speculation.......
Who is it?? who did everyone not want???
was there Controversy??? what did they do?
lee... was me cause i arked up about a few things that i didnt see right or was treated by other people (certain members that arent in here anymore).
Oh....
otay....
well as long as it was a just argument. I personly have no problem with anyone, as long as the club meeting go well i reakon everyone shold be invited.... but if your gonna cause trouble it can bring the whole club down
then i'll have to kick up a fuss
I really doubt that people would fight on cruises
If it happens then somthing would need to be done, you cant deny people based on speculation about what they MAY do
umm, i think if the statements of wanting to meet at milton at 10pm on a thursday night (one of brisbane's hot spots) to start a fight with some people would give some indication that if he doesnt get a chance before a "club cruise", then he may just take up that chance on the club cruise instead.
there would need to be motivation but organisin somethin like that in a public place at a hot spot is cause for concern of a cruise.
just one thing that we wouldnt want is for somethin like this to be displayed on an offical sau event, specially if kids are around.
Yes he MAY do it
I MAY stab some hookers on the way home tonight, But im not going to jail
baaaaaaaaaaaaaahahaha hey bunts I get jokes :O
lol
So a 33 would need to make about 280ish
If you do the power to weight calcualtaions a R33 needs a bit over 300rwkw (If I remember correctly from about 6 motnhs ago)
lol
Doh, probably wouldnt make that without going forged internally.
Ill still be happy with a mid-low 12
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
