Guess how much I have spent....you will hate me
nah no quarter mile time yet, I have had it since Feb this year....and been replacing stuff and trying to get ti to run properly since July :happy: lol
try finding someone to tune an FCONV...it doesnt happen in qld...so I used to have to contend with an extremely anoying idle and some very rich afr's. I believe that Matty Spry might have the software now though.
that's easily fixed, bust out the scissors, cut Mr HKS off and wire in Mr MOTEC :happy:
no idea... 20K?
And for the record that 13,250 is how much the car cost me btw :happy:
All ive changed is fluids :P
Ahhh I see in that case you are doing better than me :P
It would be good if he did have it! They are an awesome computer
With the 3037s what was the boost response like?
was going to but never got around to it and eventually sold the car.....to tempting. I need my license and it was annoying to go driving and worry about the police pulling me over for a check and going, excuse me sir but why does that screamer pipe vent into the atmosphere? (amongst otherthings) Im going to wait and have 2 cars, one for track and one for the street. Its a much better and safer equation. I do miss the fun though..alot!
money wise maybe - performance wise not :happy:
im not a childrens anymore though :P
have to make house payments now so cant just willy nilly buy things
am EXTREMELY happy with my car though! skylines are sooo cool!
Ahhh I see in that case you are doing better than me :happy:
It was good for a turbo of its size, I had cams which aided it, but it came on around the 3800-4000 mark at 1bar.
You will be first on the list Anna!
Hey when do you need the mone for the NYE thing. Looks like there will be 2 of us
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :happy:
your right about the fconv too, they are an awesome computer...just very hard to tune being they are in japanese and almost noone in aust has the software. Other than that they have so many features and allow an amazing tune. My car had been tuned by garage saurus in japan but they must have made the map a lot richer when the car was sold because the afr's were a joke when it was dyno'd at millenium.
money wise maybe - performance wise not :)
im not a childrens anymore though :)
I have spent under 15k on mods...so I guess I am still doing ok!
Hmmm thats not toooo bad *ponders*
got ny idea what the 3037 garrett equivalent is?
you mean price wise or what the difference in boost response etc is? Garrett make HKS turbos and they also make a 3037...the difference is the wheels, HKS put different wheels in their turbos to make them respond faster and smoother etc etc...But Garrett turbos are cheaper than HKS, so i guess you way up the options.
Edited by 33NIZ
A GT30 somthing?
But I bet it isnt as good :)
Its nowhere near as good, almost all HKS turbos have an equivelant Garrett turbo being that they are both made the same. But there is a big difference in response and overall peformance. I have been in cars with the exact same turbos, HKS and Garrett versions. You notice the difference.
no no i mean wats the equivalent turbo in the garrett range i.e 3040R
A GT30 somthing?
HKS only come into their own with hi boost and big rpm, otherwise the garretts are just as good. and quite frankly, if u want to pay the extra couple grand for the 'better' hks then go ahead :)
dude that's rubbish. there have been people test each turbo on the exact same motor, and the only difference they noticed was the HKS provided marginally better performance at higher than normal boost (2bar+) and high rpm
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :)
Cheers will have and a talk to the girl tonight and make it definate.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
