with what other mods?
i'm just gettin over the 200kw mark now and on 18psi
yet got a highflow myself.
nothing really - exhaust, pod, FMIC, clutch and fuel pump. (plus highflow and powerfc)
depends on what sort of highflow you got.. doubt it will be the same spec as a slide one
exhaust and all that stuff, basically the same as you, but a better turbo
How much power should his biggest one make Andy?
I have no idea, I am guessing a bit over 250rwkw
yeah i got the max size highflow (without going to a vg30 as he couldn't get one)..
i hope its not a lagmaster tho, i was after a nice punch but still retain drivablity.
Ahhh I see! The one I am talking about has the VG30 rear, It wont be laggy and the midrange is sweet
well allstar only has 2wd and i was in 4wd at salon
but i read 233KW at allstar in rwd and 208KW at salon in awd
That seems about right...That is very interesting, apparently the dyno I was on in Sydney reads the same as the Autosalon ones
that power output would be right though, wouldnt it?
with the engine being able to put out more power with rear-wheel cause the all wheel drive system isnt suckin up any power?
Cool,
So the VG30 is bigger or smaller rear?
was funny coz a mate of mine got 270awkw with stock turbo's and a 5" straight through exhaust.. oh and 19psi on stock turbs
i'm only running 12.6psi wish i could run mine on 19
YOu could......for a few weeks
Get Slide to hi flow them with steel wheels :wave:
boost controller is your friend :dry:
Shafts with out turbine wheels arent but
yeah i think its about right ya lose a little through 4wd... i'm happy either way, i drive my GTR everyday i dont need to tune it to max and max out a dyno just to see a high figure.. reliability is all i want and i've owned the car for over a year now and the only thig i've fixed is a new cv drivers side and the top tank in the radiator went a few weeks back.. other than that its been sweet..
sounds like we got us better rides then expected.
cept, i maxed out the injectors before puttin the nismo 555cc ones in which now run at 75%
which i wonder if puttin the injectors down to 70% would do any harm ?
actually, only problem i ever had with this liner is the turbo.
the inpropella/inperpella (spelling) fan was rubbing up against the housing when hittin full boost (back in those days, stock 7psi) lol
which then i was forced into actually gettin the turbo rebuilt and while i was at it, i had it high flowed.
its still going good today though!
Yes because you would have 5% less fuel when you needed it
or i could just buy bigger turbo's :wave:
looking into it after chrissy so many choices.. hks gtrs's look good
Hell yeah they are awesome (I am looking at getting one for my car) they are damn expensive but!
so wat if i up it to 80% then?
would i end up drowning the injectors in fuel?
Probably not, but you would be wasting 5% more fuel that you had to
Much difference in spool up time?
not really noticeable
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
