p.s
I want a Anthrax Kitty
It's from Full Moon wo Sagashite (Full moon), a manga turned anime about a chick who wants to be a famous singer, but she has throat cancer. Basically, she makes a deal with the death gods to transform her into a 16 year old girl, and her throat cancer is clear... ;)
how sick would one of them be! :huh:
Indeed!!!
ERA Mini Turbo: The engine is identical to that fitted to the MG Metro Turbo. It has a capacity of 1275cc and is fitted with a Garret T3 Turbocharger.
Hehe I want 101kw in a mini. That'd be so much fun!
Anna you're in my siggy now lol
Edit: Spelling error
My tres arent real semis but so I only gave them 2 seconds, At the official track day it is on Liz, you and me winner takes all, by then there will be no excuses, I will have had more experience and you wil have your car of choice....*dramatic music*
You can borrow my stock 33
Are you guys gonna do your cardboard car race on foot this time? I was a little disappointed that it didn't happen :P
Liz are you one of those lady boys from thighland
:huh::laugh:
It all depends on the budget you have obviously you can buy a modded 32 gtr track car with 500 horsies plus for the same money you can buy a newish standard evo probably cheaper. There are so many variables between the two such as driver, track, and budget however either would be considered just as capable in my opinion.
agreed, both are close enough for it to come down to the driver, but I still reckon the EVO is freindlier to the average driver.
The EVO pwns the R32 and R33 but
In fact stock for stock the R32 got beaten by the V35 at the test track! ;)
EDIT, I jut remembered the V35 got a 50m head start
i've had 3. Does that count.
i like you too! lol
but on a serious note, all this argument about what's better etc, it's all crap!!! I'm sure both of you have a lot of good points about your cars, and both of you have alot of work to do on your driving.
I have to put these rumours to rest.. I DO NOT HAVE A WANG
what tyres were on them? and dont the evos come standard with some hi-end tyres?
so many people want to prove their manhood by beating a chick!
it's just ODD!
What physical attributes does a woman have that would make her worse at driving? The fact you are a woman is beside the point ;)
In fact stock for stock the R32 got beaten by the V35 at the test track! :huh:
And a 16 year technological advantage ;)
I wouldnt build a drag car...getting beaten by 25k bigblock toranas would hurt
That would have been cool
My tres arent real semis but so I only gave them 2 seconds.
I know, and I gave them 3 because WAkie is such a technical track and they'll get more seconds than say Oran or EC.
i like you too! lol
*takes leaf out of josh's book* but i am THE best ;)
the banter will continue until it is actually taken to the track, im sure... *waits for comment regarding when that'll be*
Specs on your S13, Liz?
93 Silvia Q ;)
ok.. with an s14 adm engine, s15 brakes, shanef's gtr fuel pump, some gay intercooler.. and 3inch exhaust of course... the work has only just been completed.. got a few little problems to work out before I move onto suspension etc.
but the most important thing is it flutters better than a vl turbo :huh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
