hahahah....
I know what he package will cost fitted and tuned. Just buy another IS.
Been there done that with my car.
im only looking at realisticly one day putting in a standardish 1j anyway...a 2j with a t51r is overkill, exciting and pant wetting but overkill!
IM guessing it only plays one at a time.....
honestly though, with a big tv u coud watch 5 at once, and jsut listen to one.
i use to do it with the foxtel, 10 channels at one.
Hmmm banana, havent seen them in a while
SECOND AND THIRD RIMS ARE NICE>
That and your not going to get a TT 6sdp front cut under $7k these days too. Even if you buy the aristo TT motor, the 6 spd is atleast $3k, if you can find one.
1jz will be fun, I went through the 1.5jz faze not too long ago, can get some of the work done for trade, but meh at best my car will only be a 1500kg when stripped. far better then the 1700kg, but still a whale none the less.
Edited by Nismo_Boy
what rims do you think would suit my car?? Where were you going to get the conversion done? I need someone to do my conversion for free, i dont like my chances. rofl.
You want a manual 2j, I want an auto 1u.
Get some figures and get back to me :domokun:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
