yeah ok put another doctor back in his little box and worked whilst thinking about my 33 and the 260z I want lol
Get a 240...so much cooler looking! Either way both are better then 280 :vomit:
KIT KAT COOKIE DOUGH BARS FTW!!!!
PS I HATE YOU
yeah I have found a fully restored 260z for sale in pepper grey and the price is quite reasonable, I have no real issues selling the 200 for it as I love the look of the old z's
ohh nice pic, i want a rc car but they seem to cost too much, are electric ones any good for just mucking around with or should i get a proper gas one?
Get a hotted up electric, mine go hard.
so wat was that boost problem?
and if u dont mind telling, what did it cost?
P.S im sure theres ppl on here that coulda done everything for u minus the tuning for alot less ;)
combination of wastegate actuator and turbotech boost controller bleeding off boost (i looked at the dyno reading)
umm it was more than quoted but it did include replacing all exhaust studs and a new gasket which wasn't cheap, plus a service i wont say the exact amount as it wasnt astronomical, i can send you a pm if you wish?
and if you're referring to dan he couldn't help me at all cos he has too many jobs on his hands already.
man i'm glad i didn't get a bigger turbo tho, its a pain driving it as is, i want response darn it :)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
