yeah ok put another doctor back in his little box and worked whilst thinking about my 33 and the 260z I want lol
Get a 240...so much cooler looking! Either way both are better then 280 :vomit:
KIT KAT COOKIE DOUGH BARS FTW!!!!
PS I HATE YOU
yeah I have found a fully restored 260z for sale in pepper grey and the price is quite reasonable, I have no real issues selling the 200 for it as I love the look of the old z's
ohh nice pic, i want a rc car but they seem to cost too much, are electric ones any good for just mucking around with or should i get a proper gas one?
Get a hotted up electric, mine go hard.
so wat was that boost problem?
and if u dont mind telling, what did it cost?
P.S im sure theres ppl on here that coulda done everything for u minus the tuning for alot less ;)
combination of wastegate actuator and turbotech boost controller bleeding off boost (i looked at the dyno reading)
umm it was more than quoted but it did include replacing all exhaust studs and a new gasket which wasn't cheap, plus a service i wont say the exact amount as it wasnt astronomical, i can send you a pm if you wish?
and if you're referring to dan he couldn't help me at all cos he has too many jobs on his hands already.
man i'm glad i didn't get a bigger turbo tho, its a pain driving it as is, i want response darn it :)
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
