baahahaha that is dodgey as! and to think all that woulda needed to do is grind the bracket a lil & grab a fitting for the pump :O
haha OKAY...
i could have done a much better job myself!!!!
I kicked myself.. literally for taking my car there.
im going to oydssey thingo.. should be fun! anyone else here going?
sounds cool. Are ya gonna get your wang out?
hehehe AND its from a gtr :blink:
don't go there girlfriend *snaps fingers*
LIZ LIZ she's my man! If she can't do it NO-ONE CAN!!!
woot! lol
woot! lol
I would if i had one to get out for sure :blink:
yep, we met at the birbie island cruise.
u were standin around watchin ppl kick the ball
are you the person who had there gtr 33 up for sale? and i was there passenger up and down peachester for a lil while? lol fun !
can you pm me your mobbie number :) thanks
No need for PM... it's already in here about a million times and in the personal details thread 0400 641 593 (no pranking this time shane :O)
andy scores for the team :blink:
I'm the better scorer :P
I'm pretty sure she knows who she was, she's probably more interested to know which one you were lol
woot! lol
ooo you must be in a good mood today liz :D
I would if i had one to get out for sure :D
lies :blink:
I'm the better scorer :)
sorry, i couldnt help myself :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
