ask shane about my nice mechanically sympathetic burnout
ahh yehhh :)
limiter action ftw! :(
troy, i shall bring the sump with me on sunday :woot:
P.S HI5 to the person who cut my power at work this arvo, left at 4 :)
hahaha , it shits me that the shermanator eventually gets nadia.. lol hes a freak.
OLDNGREY, is the name <<< refering to your actually hair colour or as a joke?
My car is a 13 year old gunmetal grey R33.
And I'm 35 years old and very close to totaly grey. :(:woot::)
And I'm 35 years old and very close to totaly grey. :woot::):)
LMAO
what is it about turning thirty that makes your hair turn grey??? :)
was told by the missus the other day "oh look.... Grey hair"
YEP!!!! THANKS!!!!! :(
lol
I don't know about 30. I started going grey when I was 16.
It was good back then being not asked ID into the clubs. But now I am sure most people think My wife is my daughter. And god only knows what think about my kids.
lol
16!!!
i was lucky... found the 1st one at 31...... pretty happy about that part (just not so happy about starting to go grey)
oh well i keep my hair pretty short anyway, so it just looks blonde :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
